3CXPhone for Windows - Conference available?
Discussion in 'Windows' started by jr3151006, Jul 14, 2011.
  1. jr3151006
    jr3151006 New Member
    Jul 30, 2010
    155
    Does anyone idea if it´s possible start a conference from '3CXPhone for Windows'? How many user/extensions can be involved?
    11,077
    324
    Are you using it in conjunction with the 3CX PBX or a VoIP provider? There is a conference number on 3CX. Other than that, the attended transfer (flash, dial third party, flash, on standard sets) invokes a 3-way call.
  3. willow
    willow Member
    Mar 1, 2011
    471
    you can create a conference yes. dial the conference number and then when it asks for the id enter your unique id then * then the conference pin code.
  4. jr3151006
    Jul 30, 2010
    155
    I´m using with 3cx server.
  5. willow
    willow Member
    Mar 1, 2011
    471
    you can dial the conference bridge number for the system, if you have 2 digit extensions it is 70, 3 digit is 700, 4 digit is 7000, 5 digit is 70000 and then when it answers enter the the unique bridge id that you want to use (can be any numbers) followed by * and the conference password for the system. it will then create a conference. all other external and internal callers can dial the bdrige number above and then enter your unique number bridge and get into the conference.
    alterantely you can use myphone to create a conference and it will call everyone for you.
