3CXPhone for Windows Plugin API deployment
Daniel Dumitrache
I've built a plugin using 3CXPhone for Windows Plugin API based on the article here: https://www.3cx.com/call-center/crm-integration/
The deployment instructions on that article only describe a developer's machine situation, where you build and copy by yourself the dlls and setup the configuration by hand.
Is there some documentation related to how these plugins are deployed in a real production environment?
If you're using that approach, then you need to install the DLL you create in each agent PC. You can create an installer and send it to your agents, or manually copy the files...
Get 3CX - Absolutely Free!
3CX
