3CXPhone HTTP API-Is it possible to set DND status?
Discussion in '3CX Phone System - General' started by billthenerd, Jul 24, 2014.
  1. billthenerd
    Jul 3, 2014
    19
    I have been reading through the documentation but I don't see this as a feature.
    Is it possible to set DND status via a 3CXPhone HTTP API?
    ~www.3cx.com/blog/docs/3cx-http-api/
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi Bill,
    No this is not possible through HTTP API, only what is listed in the ref. page is.
    On the other hand it might be possible with Call Control API, have a look at the .chm documentation for v12 on http://www.3cx.com/blog/docs/call-control-api/
  3. billthenerd
    Jul 3, 2014
    19
    Thanks Pierre, I'll check that out
