3CXPhone keeps unregistered
Discussion in 'Windows' started by DesCheah, Jun 19, 2015.
  1. DesCheah
    Dec 22, 2014
    10
    I'm having an issue with 3CXPhone on my windows PC keeps unregistered and re-registered by itself automatically. It happens almost every 20mins. Any thought or idea?
    10,375
    231
    There is both a log in the application, and the Server log in the PBX that may offer some insight into why this happening.
    Do you have other PCs that are running off the same server, over the same network, with no issue? If so, then it may be something (another programme, or a setting), specific to that PC. If nothing else seems to work for you, I would suggest stopping all other background applications (one at a time), especially ones that use a network connection , to see if that makes a difference.
  3. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    In addition to leejor's steps if you are using an anti-virus make sure that it does not block the 3CX Phone for Windows.
    Regards
