3CXPhone Logo
Discussion in '3CX Phone System - General' started by wiggum123, Apr 7, 2014.
  1. wiggum123
    Apr 7, 2014
    5
    Is there a way of customising the logo on the Windows / Android / iOS versions of the Softphone?
    Ben
  2. tsukraw
    tsukraw New Member
    Mar 9, 2012
    191
    9
    No there is currently not a way to change those.
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    That a negative 3CX wont let you change the logo
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    New client just asked me the same and was a little disturbed they need to advertise for 3cx after paying for it.
  5. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    52
    Huh, since when do you have to pay for Windows / Android / iOS versions of the Softphone?
    You can use them for free, right?
    If you don’t want to see the logo you can freely use other softphones. Nobody forces you to use 3CX softphones. Or am I wrong?
  6. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Yep, the app is FREE...I paid 30 Grand for my truck and the manufacturers logo is all over it, just sayin'
  7. craigreilly
    Feb 1, 2012
    3,587
    309
    I just think it would be a nice feature that the end user could pop their own logo in there if they paid for 3cx...
  8. complex1
    Jan 25, 2010
    832
    52
    OK, now I do understand your point.
  9. leejor
    11,293
    361
    Perhaps 3CX should consider offering a paid App version, that could be customized with the end users logo while still retaining a small, more discreet, 3CX logo in a corner.
  10. brentkhack
    Apr 17, 2015
    24
    I bet a hair dryer would take care of that logo. I do agree with lee in a later reply that a paid version would be nice to change those few things.
  11. Patch1
    Jun 29, 2013
    12
    Strongly agree.
    I annoys me all desk IP phone dedicate most of the soft screen, most of the time to advertising 3CX.
    Makes sense for a free demo version. Not at all impressed in the paid version.
    It is the reason I intend to investigate other PBX software for the next update.
  12. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,336
    222
    [quote="Patch1]I annoys me all desk IP phone dedicate most of the soft screen, most of the time to advertising 3CX.
    [/quote]
    You can switch off the logo on the desk IP phones depending on the model, modify the phone template and change phone_setting.lcd_logo.mode setting
    #Configure the logo mode of the LCD screen; 0-Disabled (default), 1-System logo, 2-Custom logo;
    phone_setting.lcd_logo.mode = 0
