3CXPhone loose its connection to the API
Discussion in 'Windows' started by DIALOGSoftware, Nov 25, 2014.
  1. DIALOGSoftware
    Nov 9, 2010
    We've got a 3CX v12 up to date with 3CXPhone up to date.
    On only a computer (others 10 users are not concerned) running Win 7 64 bits, the 3CX Phone loose its connection to the 3CX Api Server.
    As a consequence, the user loose its queue frequently.
    Sometimes the 3CXPhone goes Out of the office whereas the user is on the same LAN
    What have been done :
    * fresh reinstall after deleting configuration in PROGRAMDATA
    * firewall deactivation
    * manual configuration instead of provisioning
    * tries with another account
    Do you know what could be done next to correct this issue ?
  2. norekhov
    3CX Support
    Jan 31, 2014
    53
    Please, post a bit of your log when it's reconnecting.
    There might be some exceptions or other unusal info.
    Log can be found at C:\Users\[user name]\AppData\Roaming\3CXPhone for Windows\Logs
  3. DIALOGSoftware
    Nov 9, 2010
    Here comes the logs :
