3CXPhone loses configuration after every closing
Discussion in '3CX Phone System - General' started by parkerbyron, Sep 26, 2013.
  1. parkerbyron
    Apr 12, 2013
    25
    I have 2 users that each time they close 3CXPhone their account settings are lost. When I reopen the application and double click the registration attachment it won't reload their account - it only works when the application is completely closed. Once I do get their account back up it will be lost the next time the close down 3CXPhone. They are local administrators on the machines and so far they are the only 2 out of the 50 or so I've deployed with this problem. Please advise, thanks.
    10,586
    252
    Since you have the majority of machines working, we know that it is not a 3CXPhone software problem. Which points to something different on the machines with the issue. Could it be trying to save the configuration (and failing) to a location that is inaccessible by that user?
  3. parkerbyron
    Apr 12, 2013
    25
    @leejor - I believe presuming that it must not be a 3CXPhone software issue is a bit of a stretch. It could certainly have something to do with the software and it might also have to do with some specific setting as you suggested but I'm not ruling out either just yet. Where does 3CXPhone try and save its configuration files? As I had mentioned both users are local administrators so they shouldn't be restricted to where they can save files on the local machine (assuming it isn't a system reserved location).
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    stored in app data, local. see if netframework is up to date, especially 4.0
  5. StefanW
    Jun 2, 2009
    1,210
    85
    when the phone looses its config delete once the config file it self (may from a beta or rc state)
    to find the config go to %appdata%\Roaming\3CXPhone for Windows and delete the 3CXPhone.xml
  6. parkerbyron
    Apr 12, 2013
    25
    @StefanW - that fixed it... after I deleted the XML file then recreated it from clicking the attachment in the 3CX welcome email it saved properly. Thanks!
