3CXPhone - Move Config
Discussion in 'Windows' started by essid, May 2, 2012.
  1. essid
    May 2, 2012
    I want to use 3CXPhone with windows system, but use Active directory,
    I know that the config is in Documents and Settings/user/.....
    There is the possibility to change this route for storage at virtual disk mounted with active directory?
    Thanks you.
