3CXPhone on my Desire with 3G
Discussion in 'Android' started by maax227, Oct 11, 2010.
  1. maax227
    Oct 11, 2010
    I have alredy installed the app 3CXPhone on my HTC Desire and work perfect !!!!!!!
    I have now a questions regarding the 3G. I need to use my voip account most of the day with a 3G connection.
    I dont' have for the moment a flat data subscription with my mobile phone provider but only 250MB per month.
    When 3CXPhone is always connected with 3G how many MB per day do I need? And for example, how many MB I need for an incoming or outgoing call of 5 minutes???
    Thanks for your help.
    Toni
  2. schulte
    Oct 11, 2010
  3. maax227
    Oct 11, 2010
    Thank for you answer
  4. lifeisfun
    Oct 18, 2010
    6
    Can you please post you results ?
    Also when I use 3G connection the indicator that my line is registered turns orange
    instead of green when using WIFI any idea why ?
