- Joined
- Oct 24, 2014
- Messages
- 75
- Reaction score
- 1
We would like to enable both TLS and SRTP on all of our phone calls. I've configured everything server-side for both to work, and they both work if I configure them manually on either a deskphone or a 3CXPhone. TLS has not been a problem: install the certificate beforehand via Group Policy, check the "Enable Secure SIP (TLS)" checkbox in Management Console, send new provisioning file to user and double-click it, and TLS is working. SRTP seems like it should be the same, but I've run into something that makes no sense to me, so I wonder if it's a bug.
I thought of making a script that would go through the provisioning folder and change every occurrence of <RTPTransport /> to <RTPTransport>2<RTPTransport/> regularly, but the Management Console re-creates the provisioning file just before emailing it every time I click "Send Welcome Email", so even a script like that won't allow me to configure clients for SRTP from the Management Console via the welcome email process. I can only do it by going to each computer and clicking through the settings on the softphone to select the option. This doesn't seem right. Am I missing something?
- I create a brand-new extension, nothing configured special. Open the extension in Management Console.
- Click the "Enable Secure SIP (TLS)" checkbox and click Apply. By comparing versions of the files, I can tell that in the 3CXPhone provisioning file it changes PBXSipPort from 5060 to 5061 and it sets SIPTransport from 0 to 2. That makes sense.
- Next, I click the "Switch on Secure RTP (SRTP)" checkbox and click Apply. However, the 3CXPhone provisioning file does not change at all: the Date Modified changes, so the system did something with it, but comparing the the "after" version of the file with the "before" version shows no difference.
