3CXPhone provisioning
Discussion in 'Windows' started by TheYves, May 27, 2014.
  1. TheYves
    Apr 20, 2014
    9
    Hello
    Are there any possibilities to change the default settings in 3CXPhone for all users? I'm talking about settings like supported codecs and DTMF. Or does really every user have to change these things manually after setup?
    Thanks in advance.
  2. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Unfortunately you cannot change the default settings of the 3CX Phone System. You will have to manually change this settings after setup.
    Best Regards
