3CXPhone - Queue Calls Window
Discussion in '3CX Phone System - General' started by parkerbyron, Sep 4, 2013.
  1. parkerbyron
    Apr 12, 2013
    25
    When you float the queue calls window out of the presence display the list does not size with the window. It's nice to be able to float it but regardless of how I size that window I can only see about 5 agents in the queue and I'd like to be able to see a much larger portion of the list. Is this possible? If not, please add as a feature. Thanks.
