3CXPhone Registration Fails, other Softphones Work with Exactly the Same Settings
Discussion in 'Windows' started by tech_wonderer, Jan 24, 2016.
  1. tech_wonderer
    Jan 23, 2016
    Ever since the latest builds [3CX Phone (Build 14.0.47020)/3CX Phone System (Build 47020) ] were released (December 2015), 3CX Phone fails to register on any computer in our network.
    Other soft-phones (Zoi*er, X-L*te, etc) work perfectly with the exact same settings. All ports on the server/firewall are open correctly, and pass the 3CX built-in firewall test. Nothing at all has changed, except for the version of 3cx.
    All of our other VOIP phone hardware (desk phones) connect to the server fine as well. The only issue is with the 3CX Softphone.
    I tried reverting back to an old 3CX Phone, but got the same error. This leads me to believe that it's something with the 3CX System update, not the softphone update, that has changed, and therefore made the Softphone unusable.
    Any idea of a fix? I've just been waiting for a new version to be released, or for someone else to post about the issue, but am growing impatient. Again, all other brands of softphones are connecting to the 3CX System perfectly.
    Thanks!
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    After the upgrade to the latest build, did you reprovision the 3CXPhones by sending them a new welcome mail?
  3. tech_wonderer
    Jan 23, 2016
    complex1, thank you very much for the reply.
    I had manually configured 3CX Phone in the past, so I went that route this time. I didn't think to consider provisioning using the link.
    It worked!
    Thank you again for your time!
