3cxphone - Show active calls on presence tab
Discussion in 'Ideas' started by ZenMasta, Nov 11, 2015.
  1. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    I would like to see a little more information available on the presence tab in 3cx so I don't have to use the presence popout.
    I did a mockup of the interface. If you can't see the attached file check this link
    http://buggyonpurpose.com/3cx/3cx-mini-presence.png
