3CXPhone Silent Install/Unistall
Discussion in 'Ideas' started by fabuo79, Oct 14, 2015.
  1. fabuo79
    Oct 14, 2015
    For enterprise installation i would a syntax for client Windows/Mac for silent/unistall installation with central managemnet system for software deployment tool.
    Thank You
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Already can be accomplished with most RMM tools out there.
  3. Anonymous
    Anonymous Guest
    I push it out silently via GPO without issue.
  4. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
    Maybe OP means push the 3CXPhone configuration file to workstations within package???
