3CXPhone & Snom 300
Discussion in 'Windows' started by hornetsoft, Feb 12, 2013.
  1. hornetsoft
    Nov 6, 2009
    10
    I use my deskphone when in office 3 days a week and 3CXPhone for the other 2 days at home how do I stop my deskphone ringing when I work on 3CXPhone while I am working from home and vice versa ?
  2. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    The only way to do so is unregistering, powering, or turning the volume down on the ringer.The 3cx phone you can close the app, though as long are both registered and on they will ring.
  3. leejor
    10,861
    302
    If the phone, at work, has an AC power supply (not POE)...buy a small 7 day timer. Plug the power supply into that, and set the timer to be off, on the days that you are not in the office.
