Solved 3cxPhone software not opening
Discussion in 'Windows' started by ppickens, Jul 7, 2017.
  1. ppickens
    Jun 19, 2013
    27
    12
    I have a client that recently the 3cxphone softphone will not initialize. The program shows up in task manager and disappears. As per typical troubleshooting steps, I have removed and reinstalled all C++ redistributables which did not remedy this issue. Also I have remove a recently added .net install and reinstalled it, but still to no avail. I'm not getting any indication of an error in the application logs on the machine.
  2. ppickens
    Jun 19, 2013
    27
    12
    Update: A recent .net 4.6.1 installation was the culprit. Installing .net 4.6.2 did the trick on this one.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,326
    448
    Glad the issue was resolved and thank you for sharing your solution.
