Still few things about the new Preferences dialog:
- Behavior: expand + sign
Using the new Preferences dialog, you can expand the + prefix sign not only to "00", but to a user-defined characters sequence.
Therefore, if you specify "abcd", the "+123" will be dialed as "abcd123". Moreover, if you leave that field empty, the + will be expanded to... empty, menaing it will be stripped, and the "+123" will be dialed as "123".
- Behavior: automatically check for updates
If checked, 3CXPhone will check, everytime when starts, for updates on 3CX website. If new online updates were found, you will be prompted and asked if you want to install them.
- Audio: ring also PC speaker
There are three "alerts" to choose from, including a Test button. Alerts will be played in loop.
- Audio: call waiting sound
When checked and you are in a call, an another, incoming call will play some "tweets" on the player (not ringing) audio device.
- Video: offline image
You are able to choose a custom offline image. This custom image is available per-PC-user.
- Video: source quality
You can choose desired resolution for your webcam; 3CXPhone then will choose, from those provided by your webcam, the closest one.
NOTE: this "new" Preferences dialog is, let's say, in "beta" form, not finished yet.
