3CXPhone v12.5 can´t connect to PBX
Discussion in 'Windows' started by dilo, May 2, 2015.
  1. dilo
    May 2, 2015
    All,
    after upgrading 3CX Phone System Pro to v12.5 I figured out a weird behavior:
    3CXPhone v12.0 has no probs with connecting, v12.5 won´t connect at all with exctly the same settings.
    Who has the final tip to make it work?
    Thank you
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Have you tried reprovisioning your 3CXPhone v12.5 using a welcome email ?
  3. dilo
    May 2, 2015
    how can I do that? Can´t find a description for a reprovisioning of a 3CX Phone or how to generate a wellcome email.
    Any clue?
  4. livn46
    Oct 24, 2014
    78
    In the management console, go to the Extensions section. Click on the extension in question, and one of the options on the top menu bar is Send Welcome Email (it's the option farthest to the right). That will send the provisioning file to the email address configured for the extension. You can also select multiple extensions and send several emails at once.
    With 12.5 we also seem to have lost the ability to "manually" set up 3CXPhone: they don't seem to work right unless you set up your account using a provisioning file. Not sure exactly what's different.
  5. dilo
    May 2, 2015
    Thank you so much, it worked!
    I can´t tell you how many hours I was seeking for a solution on this issue. The German forum guys stayed quiet or hadn´t an idea either. Tomorrow I will make my team happy with your solution :idea:
