3CXPhone v12 App and the Phonebook wont work
Discussion in '3CX Phone System - General' started by discover-sm, Jul 4, 2014.
  1. discover-sm
    Jul 4, 2014
    I have been playing around with 3CX v12 and the 3CXPhone Android and iPhone app.
    The phonebook sync is great, however the phone system requires a leading 0 to dial out. e.g. 0 8888 1234
    The issue I have is all my users mobile phone contacts do not have a leading 0 so that they can make standard calls from their phone. Is there any way to add a leading 0 to calls made from the Phonebook in the 3CXPhone android and iphone apps?
    I had a look at URL below, but not too much there.
    http://www.3cx.com/user-manual/phonebook/
