3cxPhone V12 Desktop Components?
Discussion in 'Windows' started by KeithB, Jul 24, 2013.
  1. KeithB
    Jul 7, 2009
    8
    We currently use the Notify External Program in the V8 Assisatant and I have found the equivalent in the V11 Desktop Components as part of my upgrade checking. As yet I have been unable to find the equivalent Notify External Program option in V12 - is it there somewhere or if not is there going to be Desktop Components or another method to Notify External Programs for V12?
