3CXPhone ver 1.1.2 for iPhone
Discussion in 'iOS' started by Vali_3CX, Oct 31, 2011.
  1. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,476
    67
    Hi all
    Our new release of 3CXPhone for iPhone, ver.1.1.2, is available on Apple Store.
    Most significant things added are the built-in 3CXTunnel and echo cancellation, but there are also alot of fixes and improvements. We tested it with iPhone and iPad running iOS5.0, iPhone iOS 4.2 and iPod iOS 4.2.
    Any feedback will be welcome.
  2. Iohades
    Oct 31, 2011
    Re: NEW: 3CXPhone ver 1.1.2 for iPhone available
    Not working on ipad 2 ios 5 . Aplication not start.
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    762
    39
    Device Info
    Phone Model: iPhone
    Generation: 3GS
    Firmware Version: 5.0
    Jailbreak: NO
    Cydia Installed: NO
    Issue Info
    Handset: Phone
    Contacts: Local
    Connection: WiFi
    Server: Internal
    Not working. Application won't start. :cry:
  4. Vali_3CX
    Dec 12, 2008
    1,476
    67
    "application don't start" - weird, since it was tested including by Apple :roll:
    Is this an upgrade or a fresh installation? If is an upgrade, please try to uninstall the old one and perform a fresh install :S
  5. complex1
    Jan 25, 2010
    762
    39
    Hi Vali,
    No, it is a fresh install.
    You see the app starting and then it is “gone”
    This also occurs when the iPhone is completely switched off.
  6. Ontwerp
    Oct 31, 2011
    Did a fresh install en no dice
    Iphone 4 32gb ios 5
  7. DervMan
    Oct 31, 2011
    Same thing here,
    Upgraded 3CX to new version via 'App Store Update' but after that the app won't start. I get the splash screen but then it disappears.
    3CX is shown in the 'running apps' bar at the bottom when you double click.
    I've tried killing 3CX and restarting but same thing.
    I've rebooted the iPhone but same thing.
    I've also tried deleting the app then reinstalling.
    iPhone 4 (not S) running iOS 5.
    Also tried with WiFi disabled.
  8. peedib
    Oct 31, 2011
    Mine too...
    work fine before in prior version and iOS 5
    but after update to v1.1.2, Crash upon opening App on both iPhone 3GS & 4 :S
    both is iOS 5 official one not beta, non jailbreak.
    already try delete App and restart the phone after that reinstall again but no help :cry:
    Do you and apple really test it before let it came out?
  9. Vali_3CX
    Dec 12, 2008
    1,476
    67
    No, we don't , we uploaded it blindly :roll:
    Frank, Ontwerp and DervMan: we just questioned Apple about this, because this issue seems to don't be "in our backyard", unfortunately. To recap:
    as I said , on our development and test devices is working - passed. on our beta-testers devices is working - passed. before sending to apple, Apple's validation tool - passed. Apple's tester tests - passed. approved. on the App Store - failed.
    Based on this sequence, my assumption is something happened after Apple's tester gave OK, and what I'm supposing is they re-sign the app with a different, perhaps new, certificate. If they sign only the app, but not the "dll"(s) inside, downloaded application will behave as you saw - in fact, application even don't starts, it's the iOS loader refusing to start the app (we already found this behavior during development and tests). Also. I'm assuming this because on the "uploading" log, provided by Apple, appeared a new stage, not seen until now: "preparing for App Store", taking around 6 min - what it means, I have no clue, it's their "kitchen".
    Let's hope we will get an answer/solution from Apple - it's very annoying and frustrating for everybody.
    vali
  10. DervMan
    Oct 31, 2011
    Thanks for the update, I appreciate it.
  11. carrega
    Oct 2, 2010
    Here is a log of the error
    10/31/11 4:37:42 PM ReportCrash Notice Formulating crash report for process 3CXPhone[221]
    10/31/11 4:37:42 PM com.apple.launchd Notice (UIKitApplication:com.3cx.iphone[0xb6c8]) Exited: Killed: 9
    10/31/11 4:37:42 PM com.apple.launchd Warning (UIKitApplication:com.3cx.iphone[0xb6c8]) Throttling respawn: Will start in 2147483647 seconds
    10/31/11 4:37:42 PM SpringBoard Warning Application '3CXPhone' exited abnormally with signal 9: Killed: 9
    10/31/11 4:37:42 PM ReportCrash Notice Formulating crash report for process 3CXPhone[223]
    10/31/11 4:37:42 PM com.apple.launchd Notice (UIKitApplication:com.3cx.iphone[0x6c32]) Exited: Killed: 9
    10/31/11 4:37:45 PM kernel Debug launchd[228] Container: /private/var/mobile/Applications/D914C17B-C9FC-4CF9-A4B6-6C5749C8A225 [69] (sandbox)
    10/31/11 4:37:45 PM com.apple.launchd Notice (UIKitApplication:com.3cx.iphone[0xc95d]) Exited: Killed: 9
    10/31/11 4:37:45 PM com.apple.launchd Warning (UIKitApplication:com.3cx.iphone[0xc95d]) Throttling respawn: Will start in 2147483647 seconds
    10/31/11 4:37:45 PM SpringBoard Warning Application '3CXPhone' exited abnormally with signal 9: Killed: 9
    10/31/11 4:37:45 PM SpringBoard Warning Application 'com.3cx.iphone' has failed to launch too many times. Not relaunching.
    10/31/11 4:37:45 PM ReportCrash Warning [VMUSampler sampleAllThreadsOfTask:withSymbolicator] returned no stacks for 3CXPhone[228]
    10/31/11 4:37:45 PM ReportCrash Notice Formulating crash report for process 3CXPhone[228]
    10/31/11 4:37:45 PM ReportCrash Error Saved crashreport to /var/mobile/Library/Logs/CrashReporter/3CXPhone_2011-10-31-163745iPhone.plist using uid: 0 gid: 0, synthetic_euid: 501 egid: 0
    10/31/11 4:37:46 PM ReportCrash Error Saved crashreport to /var/mobile/Library/Logs/CrashReporter/3CXPhone_2011-10-31-163745iPhone.plist using uid: 0 gid: 0, synthetic_euid: 501 egid: 0
    10/31/11 4:38:45 PM SpringBoard Notice Posting 'com.apple.iokit.hid.displayStatus' notifyState=0
  12. complex1
    Jan 25, 2010
    762
    39
    Hi Vali,
    Thank you for the explanation, I appreciate it.
    Is it possible to download the version just before you did upload it to the App Store?
    The tested one, by your beta-testers?
    I will not ask you for an estimated time of a new release, because you don’t know it either.
    Regards,
    Frank.
  13. Vali_3CX
    Dec 12, 2008
    1,476
    67
    Hi Frank
    The answer is: no. Apple provide a very restrictive environment in this aspect (from some points of view, is good, though): the developer can send the in-development app only to certain users, "the choosen ones", who are required to be approved (based on their devices ID) by the developer and registered by Apple. They are the ones called "beta-testers". Then, the developer send them the app, and app's certificate is checked by their iOS against Apple provided's one and only if they match the app is launched. Otherwise, your app will get the same simptom as the one we "enjoying" right now.
    L.E: carrega, thanks for the log.
  14. ATNZ
    Aug 17, 2011
    16
    Phone Model: iphone 4 (white) MC604X
    Generation: 4
    Firmware Version: 5.0 (9a334)
    Jailbreak: No
    Cydia Installed: No
    Issue Info
    Handset: Phone
    Contacts: Local and Exchange
    Connection: WiFi and 3G
    Server: Internal - 3CX v10 sp2
    I have tried this and it doesn't work for us either, same start and crash as everyone else. How long to "fix" whatever the problem is?
  15. pato
    Oct 31, 2011
    Same problem here, splashscreen and nothing more. Luckely i didnt sync the phone after upgrading so i had the old one (1.0.23) in iTunes so i could restore the app from there, working again with the old one :)
    Phone Model: iphone 3gs (MC133KS)
    Generation: 3?
    Firmware Version: 5.0 (9A334)
    Jailbreak: No
    Cydia Installed: No
    Issue Info
    Handset: Phone
    Server: IP-CENTREX, Asterisk based, fresh installed dough cause of delete and reinstall, dont think this matters
  16. novacom
    Feb 23, 2011
    any news on a fix, upgraded 3 clients at the same time and now noone is working... :cry:
  17. nakanet
    May 1, 2011
    25
    So far, so good...
    I thought the expecting 1.1.x series of the 3CX softphone for iPhone come to be the unifying solution to our enviroment, but I see that Apple is struggling with something that make the users frustrated.
    As I said in a previous post here in the forum, I´m using another SIP softphone app to keep me connected to the 3CX central, but we want to use a unified platform and we´re waiting for a long time for the release of the 1.1.x series of the 3CX Phone.
    But here in Japan, we also experimented trobles in updates or fresh installs of 3CX Phone in several equipments of our school, and gaves us a big trouble, because we lost the previous version of 3CX phone and we had, in an emergency operation, install and set up some equipments of our company to the ageet´s softphone to keep the network operational.
    Hope we can have a solution for this trouble in a short period of time.
    Best regards.
    Eduardo Nakagawa
    Director
    Nakanetworks Japan
  18. Nick Hoogland
    Mar 6, 2010
    The new version does also not work on the iPod (second generation) with IOS 4.3.3. The behavior for the iPod is similar to earlier posts: just a splash screen after which the application disappears to the background. Application restart and iPod reboot does not solve the problem.
  19. ATNZ
    Aug 17, 2011
    16
    It would be very helpful if we could get an update as to what the plan is to resolve this and get a 1.1.x version out that works?
  20. LCC
    LCC
    Jul 8, 2011
    42
    Same here. App crashes on launch.
