3CXPhone via Tunnel one-way audio
Discussion in '3CX Phone System - General' started by hivanov, Dec 9, 2013.
  1. hivanov
    Apr 25, 2012
    22
    Hi all !
    We have some remote extensions worldwide using 3CXPhone via the 3CX tunnel. After installing v12 SP3 these extensions suffer from one-way and sometimes no audio. I've tested with all the versions of 3CXPhone ( windows, android and iOS) and the problem still exists. The successful rate of normal calls is about 10%. Remote extensions configured without using the tunnel works fine. I've tried to revert the v12SP2 and the problem disappeared. Please tell me if there is something new according to the tunnel settings in SP3 ?
    Thanks in advance !
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Submit a ticket to 3CX support, providing logs, etc.
  3. hivanov
    Apr 25, 2012
    22
    I've submitted a ticked to the support team. I'll keep you in touch with the solution of the problem 8|
