3cxphone4 not installing on windows7
Discussion in 'Windows' started by shinoj, May 21, 2010.
  1. shinoj
    May 21, 2010
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    After googling your issue ( Could not access vbscript for custom action ) i found the following:
    http://www.nitropdf.com/kb/article.aspx?id=10106
    This is pretty much the same procedure for anyone who is getting this script error on any program.
  3. regisp
    Oct 4, 2010
    Just followed both options mentioned here and still get the same message "could not access VBScript run time for custom action". Any of what it could be?thanks
  4. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    I cannot help you directly - installer's issues are beyond me - but I suggest you a workaround:
    3CXPhone - at least the latest Beta 5 - is fully standalone. Therefore, if you have it installed on another machine, just copy its installation folder from there - usually C:\Program Files\3CXphone - and paste it on any convenient place on your Windows 7. To "uninstall" it later - only delete its folder.
    Hope it helps
    vali
  5. regisp
    Oct 4, 2010
    thanks for your help Vali...didn't work neither for me...love IT, hate IT! :mrgreen: thanks god this is Thursday night 8)
  6. LeonidasG
    Nov 19, 2008
    1,473
    94
    Saturday Night fever is the best though!
  7. Vali_3CX
    Dec 12, 2008
    1,479
    67
    OK, in this case is mine :mrgreen: So, in which way it doesn't work? You cannot run it/start it/register it? Do you get any error message box?
  8. LeonidasG
    Nov 19, 2008
    1,473
    94
    I can't tell you much more regarding Windows Script errors.
    This link here seems to work for every single other person out there but not you :mrgreen:
    http://www.nitropdf.com/kb/article.aspx?id=10106&cNode=3D8W4P
    Could you re-visit it and make sure you did everything correctly?
