3CXPhone6
Discussion in 'Windows' started by drghughes, May 1, 2011.
  1. drghughes
    May 1, 2011
    6
    Some of the download links on the web site are now to version 6 - http://www.3cx.com/downloads/3CXPhone6.msi - while some are still to version 5.
    Does anyone know anything about version 6? Are there any release notes? Anyone used it and have some comments?
    Thanks!
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Yes, we released version 6 - a description will be available soon. There are not so many changes compared to ver 5, the most significant one (from my point of view) is related to BLFs.
    Regards
    vali
  3. drghughes
    May 1, 2011
    6
