3cxPhoneforWindowa 12.5
Discussion in '3CX Phone System - General' started by donbru01, Jan 29, 2015.
  1. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    I have this issue
    Incoming call from other VideoPhone example GXV3175 V2 where priority codec is H264 , second H263 video not work
    incoming call from other VideoPhone example GXV3175 v2 where priority codec is h263 , second h264 video work
    I know that 3cxPhonefor Windows 12.5 not use h264 , but if not use this codec it must send in sdp only h263
    Anyone had same issue?
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    More information is needed as to the situation.
    I assume the phones are within the same LAN? Both phones are 3175s? You mention the 12.5 Phones for Windows, but not where it fits into your scenario. You also did not indicate if when "video work" if that means that video was observable on both ends, or if on one end...which.
    As far as I know, the 3CXPhoneforWindows, does not support video itself, but it can be used to support WEBRTC conferencing whose video is separate. The earlier 3CX Phone softphone V6 does support video at a h263 level. This is a generic softphone.
    Perhaps providing more detail will help.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Hi , scenario
    Ext 2438 is 3cx client phone for windows latest version
    Ext 2000 is gxv3175v2
    Ext 2001 is yealink vp530
    Ext 2002 is 3cx client phone for windows latest version
    All device on same network
    Any video call 2438 to 2002 , or 2438 on webrtc with another devixe work fine
    Any video 2000 to 2001 work fine
    Video call 2438 from or to 2001 or 2000 work fine only if hardphone is setting with first codec h263 and work fine
    If hardphone 2001 or 2000 is setting with codec h264 and second code with h263 , video call not start only audio
