3cxsbc for Linux x86
Discussion in 'Ideas' started by Telcreek, Dec 31, 2016.
3cxsbc for Linux x86 5 5 1votes
5/5, 1 vote
Tags:
  1. Telcreek
    Dec 30, 2016
    27
    I see a version compiled for ARM (Raspi) but not x86. The advertised limitations of 3cxsbc on a Raspi are 5 or so extensions/calls so to scale beyond appears to require a Windows box at the moment. I'd love to run the sbc at larger sites without running it on a Windows license. I have to imagine this is in the works, considering the Raspberry Pi version, but figured it didn't hurt to ask. I did not see a previous request but apologies if I missed it.
  2. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    173
    60
    For version 15, the SBC limitations have changed - if you are using a PI2 or PI3. The original code was single threaded and so it could not use the additional horsepower of the PI+, but V15 of SBC fixes that. Now the limits are upwards of 20 extensions with BLFs.
    On a pre-existing pi, do this:
    sudo apt-get update
    sudo apt-get upgrade
    Say no when it asks if you want it to overwrite CONF file.
    Use HTOP to watch it work...
  3. Telcreek
    Dec 30, 2016
    27
    Thanks! That helps for some larger satellites for sure.
  4. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    421
