3cxv14 too long install on win2008
Discussion in 'Windows' started by proby, Oct 13, 2015.
  1. proby
    Oct 10, 2015
    11
    Why I have too long install 3cx v14 phone system on windows server 2008 r2 x64 ,maybe 1 hour?? 3cx v12 had short normall installation.
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Did you select virtual cloud installation? If yes, it will take time because it's creating 25 instances.
  3. proby
    Oct 10, 2015
    11
    yes 25 instances, 1 hour,thnx
