3CXVoipPhone.ocx
Discussion in 'Windows' started by sergie, Jun 18, 2010.
  1. sergie
    Jun 18, 2010
    i want to use 3CXVoipPhone.ocx to call from my application.
    Where i can read about methods and parameters?
    At first i want to get connection, but function 'Connect' return False.
    Thnx
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,531
    69
    3CXphone activex is no longer supported - latest versions even no longer include it in the installation package.
