3CXWin8Phone - Background Process
Discussion in '3CX Phone System - General' started by ian.watts, May 18, 2015.
  1. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Have a user whose app doesn't display a window.
    It's not on the taskbar nor the tray.
    All I'm getting is the "3CXPhone for Windows (32 bit) listed as a Background Process.
    Logged on as the admin, got it to list as an app which I could Bring to Front.. but after switching users twice now I cannot.
    Uninstall/reinstall was done first.. no dice.
    I tried gutting the files from c:\programdata and c:\program files (x86) between the next round of uninstall.. no dice.
    Found some registry.. still no dice.
    As a new user, it didn't show up on the admin console to add an extension et al.
    This user was on it for probably two weeks until letting me know it isn't working this morning.
    Ideas?
    12.5.39117.982
    Maybe some 12.5 SP1?.. seems to be more about SHA1 fun than this.
    Client is 50% softphone.. I could push SP1 tonight but it certainly means "updates" are coming for all.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    832
    52
    Is both Microsoft .Net 4.0 or 4.5 and Microsoft Visual C++ 2010 x86 installed on the machine?
    Did you reboot after install?
  3. ian.watts
    Apr 8, 2011
    532
    VC++ 10.0.40219, both x86 and x64
    Not seeing .Net 4/ 4.5 on the Programs and Features nor the Installed Updates list.
    Are you suggesting I throw on some 4.5 and see what happens?
    I'll be contacting support if I can't nail this one down.. got a second PC going quirky with this app now.
  4. complex1
    Jan 25, 2010
    832
    52
    Yes. .Net 4/4.5 must be installed on your machine also. Only Visual C++ is not sufficient enough.
  5. ian.watts
    Apr 8, 2011
    532
    It doesn't explain why it was working for a couple of weeks and two stopped around the same time frame.
    4.5.2 was installed already. Removing it and doing it again.
    Nope.
    From there, uninstalled and reinstalled from a fresh download.. nope.
    This activity was done on the "second" computer exhibiting this problem.
    I'll be calling 3CX tomorrow morning to see what can be done.
  6. ian.watts
    Apr 8, 2011
    532
    Follow up from Friday: Though it was a valiant effort, no dice. Two hours in, the ticket was escalated.
    Fortunately my poor user is in a patient culture which works with children.. other clients' users would be in a fit after three minutes.
  7. admitionon
    May 26, 2015
    Nooooo!! I've had same problem like you !!!But after I reinstall it...it worked
    http://www.coqueperia.com/category-housse-sony-xperia-z4-15.html
