3cxWin8Phone doesn't start
Discussion in 'Windows' started by MartinSB, Oct 28, 2016.
  1. MartinSB
    Oct 28, 2016
    Hello
    Ever since we updated to v15, literally NOTHING works.
    Currently I am nearly in tears trying to set up a laptop for one of our employees.
    Brand new, unused Dell laptop with Windows 8.1 installed. One of the first things I am trying to do is installing the 3cx client. Installation goes fine, and then on the last step we have "launch 3cx client". Unfortunately nothing happens.
    So then I try to run the app from the shortcut on the desktop - nothing happens. Checked processes - nothing there.
    Has anyone got any idea as to what is going on, please?
    Kindest regards
    Martin
  2. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    183
    16
  3. MartinSB
    Oct 28, 2016
    Thanks for your reply. I was being thick and panicked. Since it was a clean and new Windows 8.1, it had 293 missing updates. Took all night to download/install them and it's all working fine now.
    Cheers
