3rd Party Call Logging/Reporting software?
Discussion in '3CX Phone System - General' started by adminbod, Sep 8, 2016.
  1. adminbod
    Jan 18, 2010
    36
    Hi -
    I was wondering if anyone had suggestions of 3rd party applications they use with the 3CX CDR service?
    Ideally it would be an off-the shelf application/service (local install or cloud) that could hook into the 3CX's CDR service, pull the call data out and then allow more detailed custom reports to be generated.
    any suggestions welcome.
    many thanks...
    10,752
    285
  3. adminbod
    Jan 18, 2010
    36
    Thanks Lee,
    Yes, I've already spoken to voiptools about an application they have called 'exporter' - that retrieves the CDR logs from 3CX and puts them in a database (SQL or MySQL) which you could then use to build your own reports.
    Its an option, and theoretically a good one - but I was hoping there might be an application that had the report generation front-end already in place.
    cheers...
  4. tomnorton
    Feb 23, 2015
    21
    We use TIM Enterprise from Tri-Line http://www.tri-line.com
    Full support for 3CX, very quick install. Provides nice HTML interface for call logs and reports.
    Their support is very good too.
    Regards
    Tom
  5. oneclick
    Jul 19, 2011
    We're currently developing a cloud hosted solution for call center reports that extracts data from the 3CX database, not only CDRs. Would you like me to notify you when we have an update? Are you or your client a call center?
  6. adminbod
    Jan 18, 2010
    36
    Hey oneclick - did this ever get off the ground?
