3xc Provisoning and Snom 715 unattended transfer impossible to do
Discussion in '3CX Phone System - General' started by nikosT_3cx, Dec 15, 2015.
  1. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    please make sure that the Snom phone is provisioned with the default template and that it is on the supported firmware provided form 3cx. Since the phone is provisioned and you have valid maintenance then go on the Management Console>> Phones>> Select the extension and press Firmware Upgrade to download the tested and supported from our side.
    Snom 715 has the ability to perform blind transfer.
    When you are on line one, press the xfer button dial the number of the extension you want and confirm the transfer with the tick button.
