- Joined
- Apr 7, 2007
- Messages
- 121
- Reaction score
- 0
When creating a VOIP line in 4.0 Alpha it fails and the details of the event follow. I am using the same settings for Broadvoice I have used successfully with previous versions.
Cannot save External Line object: ERROR: insert or update on table "externalline" violates foreign key constraint "externalline_fkidfaxdn_fkey"<br />
DETAIL: Key (fkidfaxdn)=(0) is not present in table "dn".<br>#0 C:\Program Files\3CX PhoneSystem\Data\Http\functions\CallContext.php(94): safeExec(Object(PDOStatement), 'Cannot save Ext...')<br />
#1 C:\Program Files\3CX PhoneSystem\Data\Http\functions\fExternalLine.php(77): CallContext->safeExec('insert into ext...', Array, 'Cannot save Ext...')<br />
#2 C:\Program Files\3CX PhoneSystem\Data\Http\gateway_lines_upd.php(869): fExternalLine::save(Object(oExternalLine))<br />
#3 {main}
#3 {main}
