leejor said:Unless the phones are setup to download a new configuration, and just did, (which is causing the issue). then you may need to look elsewhere on your network. Does the 3CX log show any indication of a registration attempt? Did anything else change on your network that coincides with this problem?
leejor said:One bad phone, maybe, but for all to fail it would have to be something that they all downloaded together.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
