400 Bad Request
Discussion in '3CX Phone System - General' started by ngtech, Sep 12, 2010.
  1. ngtech
    Apr 20, 2009
    7
    Ok,
    so I setup a 3CX 3U appliance with 20 Cisco 504G phones, a couple of Snom M3's and have a 6 SIP trunk line through Broadvox through a Cisco RV082 router. Everything configured and setup perfect at office network.
    Move all equipment to customer site. Setup everything, change external IP on router and in 3CX fields where needed to match customer's static IP config and we can receive calls through VOIP Provider, make internal calls, but cannot call out. As soon as you try, phone read "server internal error".
    Server Activity Log shows (xxx'd out phone number for security):
    21:07:11.645 [CM503016]: Call(4): Attempt to reach <sip:9173xxxxxxx@192.168.10.240> failed. Reason: Not Acceptable HereReason Unknown
    21:07:11.644 [CM503003]: Call(4): Call to sip:173xxxxxxx@208.93.226.213:5060 has failed; Cause: 400 Bad Request; from IP:208.93.226.213:5060
    What gives?
  2. ngtech
    Apr 20, 2009
    7
    Here is resukt from Firewall Checker:
    3CX Firewall Checker, v1.0. Copyright (C) 3CX Ltd. All rights reserved.
    <00:24:07>: Phase 1, checking servers connection, please wait...
    <00:24:07>: Stun Checker service is reachable. Phase 1 check passed.
    <00:24:07>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
    <00:24:07>: UDP SIP Port is set to 5060. Response received correctly with no translation. Phase 2a check passed.
    <00:24:07>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <00:24:08>: TCP SIP Port is set to 5060. Response received correctly with no translation. Phase 2b check passed.
    <00:24:08>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
    <00:24:08>: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
    <00:24:08>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
    <00:24:21>: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
    <00:24:21>: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passed.
    <00:24:21>: UDP RTP Port 9002. Response received correctly with no translation. Phase 4-03 check passed.
    <00:24:21>: UDP RTP Port 9003. Response received correctly with no translation. Phase 4-04 check passed.
    <00:24:21>: UDP RTP Port 9004. Response received correctly with no translation. Phase 4-05 check passed.
    <00:24:21>: UDP RTP Port 9005. Response received correctly with no translation. Phase 4-06 check passed.
    <00:24:21>: UDP RTP Port 9006. Response received correctly with no translation. Phase 4-07 check passed.
    <00:24:21>: UDP RTP Port 9007. Response received correctly with no translation. Phase 4-08 check passed.
    <00:24:21>: UDP RTP Port 9008. Response received correctly with no translation. Phase 4-09 check passed.
    <00:24:21>: UDP RTP Port 9009. Response received correctly with no translation. Phase 4-10 check passed.
    <00:24:21>: UDP RTP Port 9010. Response received correctly with no translation. Phase 4-11 check passed.
    <00:24:21>: UDP RTP Port 9011. Response received correctly with no translation. Phase 4-12 check passed.
    <00:24:21>: UDP RTP Port 9012. Response received correctly with no translation. Phase 4-13 check passed.
    <00:24:21>: UDP RTP Port 9013. Response received correctly with no translation. Phase 4-14 check passed.
    <00:24:21>: UDP RTP Port 9014. Response received correctly with no translation. Phase 4-15 check passed.
    <00:24:21>: UDP RTP Port 9015. Response received correctly with no translation. Phase 4-16 check passed.
    <00:24:21>: UDP RTP Port 9016. Response received correctly with no translation. Phase 4-17 check passed.
    <00:24:21>: UDP RTP Port 9017. Response received correctly with no translation. Phase 4-18 check passed.
    <00:24:21>: UDP RTP Port 9018. Response received correctly with no translation. Phase 4-19 check passed.
    <00:24:21>: UDP RTP Port 9019. Response received correctly with no translation. Phase 4-20 check passed.
    <00:24:21>: UDP RTP Port 9020. Response received correctly with no translation. Phase 4-21 check passed.
    <00:24:21>: UDP RTP Port 9021. Response received correctly with no translation. Phase 4-22 check passed.
    <00:24:21>: UDP RTP Port 9022. Response received correctly with no translation. Phase 4-23 check passed.
    <00:24:21>: UDP RTP Port 9023. Response received correctly with no translation. Phase 4-24 check passed.
    <00:24:21>: UDP RTP Port 9024. Response received correctly with no translation. Phase 4-25 check passed.
    <00:24:21>: UDP RTP Port 9025. Response received correctly with no translation. Phase 4-26 check passed.
    <00:24:21>: UDP RTP Port 9026. Response received correctly with no translation. Phase 4-27 check passed.
    <00:24:21>: UDP RTP Port 9027. Response received correctly with no translation. Phase 4-28 check passed.
    <00:24:21>: UDP RTP Port 9028. Response received correctly with no translation. Phase 4-29 check passed.
    <00:24:21>: UDP RTP Port 9029. Response received correctly with no translation. Phase 4-30 check passed.
    <00:24:21>: UDP RTP Port 9030. Response received correctly with no translation. Phase 4-31 check passed.
    <00:24:21>: UDP RTP Port 9031. Response received correctly with no translation. Phase 4-32 check passed.
    <00:24:21>: UDP RTP Port 9032. Response received correctly with no translation. Phase 4-33 check passed.
    <00:24:21>: UDP RTP Port 9033. Response received correctly with no translation. Phase 4-34 check passed.
    <00:24:21>: UDP RTP Port 9034. Response received correctly with no translation. Phase 4-35 check passed.
    <00:24:21>: UDP RTP Port 9035. Response received correctly with no translation. Phase 4-36 check passed.
    <00:24:21>: UDP RTP Port 9036. Response received correctly with no translation. Phase 4-37 check passed.
    <00:24:21>: UDP RTP Port 9037. Response received correctly with no translation. Phase 4-38 check passed.
    <00:24:21>: UDP RTP Port 9038. Response received correctly with no translation. Phase 4-39 check passed.
    <00:24:21>: UDP RTP Port 9039. Response received correctly with no translation. Phase 4-40 check passed.
    <00:24:21>: UDP RTP Port 9040. Response received correctly with no translation. Phase 4-41 check passed.
    <00:24:21>: UDP RTP Port 9041. Response received correctly with no translation. Phase 4-42 check passed.
    <00:24:21>: UDP RTP Port 9042. Response received correctly with no translation. Phase 4-43 check passed.
    <00:24:21>: UDP RTP Port 9043. Response received correctly with no translation. Phase 4-44 check passed.
    <00:24:21>: UDP RTP Port 9044. Response received correctly with no translation. Phase 4-45 check passed.
    <00:24:21>: UDP RTP Port 9045. Response received correctly with no translation. Phase 4-46 check passed.
    <00:24:21>: UDP RTP Port 9046. Response received correctly with no translation. Phase 4-47 check passed.
    <00:24:21>: UDP RTP Port 9047. Response received correctly with no translation. Phase 4-48 check passed.
    <00:24:21>: UDP RTP Port 9048. Response received correctly with no translation. Phase 4-49 check passed.
    <00:24:21>: UDP RTP Port 9049. Response received correctly with no translation. Phase 4-50 check passed.
    Application exit code is 0
