- Joined
- Oct 26, 2010
- Messages
- 8
- Reaction score
- 0
Currently I've set up 3CX server which is configured as it should be, atleast I think so. The company I'm implenting this PBX has a seperate VoIP-Network with a own firewall. Here are the logs of my 3CX Firewall check:
<13:41:42>: Phase 1, checking servers connection, please wait...
<13:41:42>: Stun Checker service is reachable. Phase 1 check passed.
<13:41:42>: Phase 2a, Check Port Forwarding to UDP SIP port, please wait...
<13:41:42>: UDP SIP Port is set to 5060. Response received WITH TRANSLATION 61013::5060. Phase 2a check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<13:41:42>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
<13:41:43>: TCP SIP Port is set to 5060. Response received WITH TRANSLATION 61013::5060. Phase 2b check passed with WARNINGS. Some functionality will be LIMITED. For more information, please visit http://www.3cx.com/blog/docs/firewall-checker/
<13:41:43>: Phase 3. Check Port Forwarding to TCP Tunnel port, please wait...
<13:41:43>: TCP TUNNEL Port is set to 5090. Response received correctly with no translation. Phase 3 check passed.
<13:41:43>: Phase 4. Check Port Forwarding to RTP external port range, please wait...
<13:41:48>: UDP RTP Port 9000. Response received correctly with no translation. Phase 4-01 check passed.
<13:41:48>: UDP RTP Port 9001. Response received correctly with no translation. Phase 4-02 check passed.
<13:41:48>: UDP RTP Port 9002. Response received correctly with no translation. Phase 4-03 check passed.
<13:41:48>: UDP RTP Port 9003. Response received correctly with no translation. Phase 4-04 check passed.
<13:41:48>: UDP RTP Port 9004. Response received correctly with no translation. Phase 4-05 check passed.
<13:41:48>: UDP RTP Port 9005. Response received correctly with no translation. Phase 4-06 check passed.
<13:41:48>: UDP RTP Port 9006. Response received correctly with no translation. Phase 4-07 check passed.
<13:41:48>: UDP RTP Port 9007. Response received correctly with no translation. Phase 4-08 check passed.
<13:41:48>: UDP RTP Port 9008. Response received correctly with no translation. Phase 4-09 check passed.
<13:41:48>: UDP RTP Port 9009. Response received correctly with no translation. Phase 4-10 check passed.
<13:41:48>: UDP RTP Port 9010. Response received correctly with no translation. Phase 4-11 check passed.
<13:41:48>: UDP RTP Port 9011. Response received correctly with no translation. Phase 4-12 check passed.
<13:41:48>: UDP RTP Port 9012. Response received correctly with no translation. Phase 4-13 check passed.
<13:41:48>: UDP RTP Port 9013. Response received correctly with no translation. Phase 4-14 check passed.
<13:41:48>: UDP RTP Port 9014. Response received correctly with no translation. Phase 4-15 check passed.
<13:41:49>: UDP RTP Port 9015. Response received correctly with no translation. Phase 4-16 check passed.
<13:41:49>: UDP RTP Port 9016. Response received correctly with no translation. Phase 4-17 check passed.
<13:41:49>: UDP RTP Port 9017. Response received correctly with no translation. Phase 4-18 check passed.
<13:41:49>: UDP RTP Port 9018. Response received correctly with no translation. Phase 4-19 check passed.
<13:41:49>: UDP RTP Port 9019. Response received correctly with no translation. Phase 4-20 check passed.
<13:41:49>: UDP RTP Port 9020. Response received correctly with no translation. Phase 4-21 check passed.
<13:41:49>: UDP RTP Port 9021. Response received correctly with no translation. Phase 4-22 check passed.
<13:41:49>: UDP RTP Port 9022. Response received correctly with no translation. Phase 4-23 check passed.
<13:41:49>: UDP RTP Port 9023. Response received correctly with no translation. Phase 4-24 check passed.
<13:41:49>: UDP RTP Port 9024. Response received correctly with no translation. Phase 4-25 check passed.
<13:41:49>: UDP RTP Port 9025. Response received correctly with no translation. Phase 4-26 check passed.
<13:41:49>: UDP RTP Port 9026. Response received correctly with no translation. Phase 4-27 check passed.
<13:41:49>: UDP RTP Port 9027. Response received correctly with no translation. Phase 4-28 check passed.
<13:41:49>: UDP RTP Port 9028. Response received correctly with no translation. Phase 4-29 check passed.
<13:41:49>: UDP RTP Port 9029. Response received correctly with no translation. Phase 4-30 check passed.
<13:41:49>: UDP RTP Port 9030. Response received correctly with no translation. Phase 4-31 check passed.
<13:41:49>: UDP RTP Port 9031. Response received correctly with no translation. Phase 4-32 check passed.
<13:41:49>: UDP RTP Port 9032. Response received correctly with no translation. Phase 4-33 check passed.
<13:41:49>: UDP RTP Port 9033. Response received correctly with no translation. Phase 4-34 check passed.
<13:41:49>: UDP RTP Port 9034. Response received correctly with no translation. Phase 4-35 check passed.
<13:41:49>: UDP RTP Port 9035. Response received correctly with no translation. Phase 4-36 check passed.
<13:41:49>: UDP RTP Port 9036. Response received correctly with no translation. Phase 4-37 check passed.
<13:41:49>: UDP RTP Port 9037. Response received correctly with no translation. Phase 4-38 check passed.
<13:41:49>: UDP RTP Port 9038. Response received correctly with no translation. Phase 4-39 check passed.
<13:41:49>: UDP RTP Port 9039. Response received correctly with no translation. Phase 4-40 check passed.
<13:41:49>: UDP RTP Port 9040. Response received correctly with no translation. Phase 4-41 check passed.
<13:41:49>: UDP RTP Port 9041. Response received correctly with no translation. Phase 4-42 check passed.
<13:41:49>: UDP RTP Port 9042. Response received correctly with no translation. Phase 4-43 check passed.
<13:41:49>: UDP RTP Port 9043. Response received correctly with no translation. Phase 4-44 check passed.
<13:41:49>: UDP RTP Port 9044. Response received correctly with no translation. Phase 4-45 check passed.
<13:41:49>: UDP RTP Port 9045. Response received correctly with no translation. Phase 4-46 check passed.
<13:41:50>: UDP RTP Port 9046. Response received correctly with no translation. Phase 4-47 check passed.
<13:41:50>: UDP RTP Port 9047. Response received correctly with no translation. Phase 4-48 check passed.
<13:41:50>: UDP RTP Port 9048. Response received correctly with no translation. Phase 4-49 check passed.
<13:41:50>: UDP RTP Port 9049. Response received correctly with no translation. Phase 4-50 check passed.
Currently the number that is registered as a VoIP-Provider in 3CX can't receive any phonecalls from outside numbers, but it can make phonecalls to both in- and outside numbers, but when I call an outside number I will receive a call from a unknown caller. This number is currently also in use by other SIP-Phones which aren't connected to the 3CX PBX, this shouldn't really be a problem. The SIP-Phones that are directly connected to the VoIP-Provider and not to the 3CX PBX can receive and make calls and work as intended. Now I went to check with Wireshark about what might go wrong when making a call to an outside number and I'm getting the following message:
Source: 91.xxx.xxx.x - Destination: 192.xxx.xxx.xx - Protocol: SIP - Info: Status: 401 Unauthorized
How is this possible if I can make a outside phonecall and actual talk? I've double-checked all the accountsettings and are all correctly filled in. I'm having the feeling I'm just forgetting something but can't figure it out. Thanks in advance.
