401 Unauthorized with sipgate voip provider
Discussion in '3CX Phone System - General' started by maja10, Jan 14, 2010.
  1. maja10
    Jan 14, 2010
    Hi All
    I'm new to 3CX and SIP
    Apologies if this question has been posted before but I can't seem to find a solution for this.
    I'm using Sipgate as the VOIP providor, and I'm unable to connect, this is the error I get from the server activity section in the 3cx Management Console
    20:24:18.718 [CM504005]: Registration failed for: 10000@Sipgate; Cause: 401 Unauthorized; from IP:217.10.79.23:5060
    I'm assuming the IP Adress is the server's as it isn't mine.
    I've sucessfuly managed to call a softphone on my laptop which is pointing to my external IP Address (where the server is based), so I'm assuming connectivity is ok.
    Any help would be much appreciated
    Mark
    10,360
    226
    Double check your password and user name.
  3. maja10
    Jan 14, 2010
    Checked that, still no change
    Any ideas?
