403.14 Forbidden on management app - does not redirect
Discussion in '3CX Phone System - General' started by mcbsys, Dec 15, 2012.
  1. mcbsys
    mcbsys New Member
    Oct 8, 2008
    186
    15
    I'm running 3CX 11.0.26364.600 on a 32-bit, domain-joined Windows 7 virtual machine. The web server is IIS.
    It's a test system but I'm almost positive I used to be able to access the admin portal across the intranet by just typing "http://localhost:5000/".
    A couple weeks ago, I created a new domain server and migrated the 3CX machine to the new domain. Not sure if this is related.
    Now I have these symptoms:
    - "http://localhost:5000/" on the 3CX server yields "HTTP Error 403.14 - Forbidden. The Web server is configured to not list the contents of this directory."
    - "http://localhost:5000/management/MainForm.wgx" works fine.
    Isn't it supposed to redirect to the management app by default? How/where is that configured?
    Thanks,
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    As far as a default, I have not observed that behavior. I have however observed where if you simply use http://local host:5000/management , it will take you to the mainform.wgx by default.my guess is that you have to at least provide a folder/name after the :5000 as the same port is used for MyPhone, reports and provisioning.
  3. mcbsys
    mcbsys New Member
    Oct 8, 2008
    186
    15
    Thanks, that works.
