403 error when accessing from public IP
Discussion in '3CX Phone System - General' started by asmith3006, Aug 2, 2016.
  1. asmith3006
    Mar 5, 2014
    94
    5
    I'm having a hard time accessing the management interface from an external IP address and I'm not sure if this is a router/firewall or 3cx issue so hoping someone can help.
    I've mapped port 5000 from external to internal IP address. If I go (from a a remote site) to 1.2.3.4:5000 then I get a 403 response. I've turned the server off and the response times out so I'm definitely talking to the correct server.
    If I access the server on the internal IP (172.27.10.11:5000) then I get the admin interface correctly.
    The fact I'm getting a 403 suggests I've got everything setup correctly, is there a setting which is preventing me from accessing it from the outside world? Some security setting I need to tick?
  2. datamerge
    datamerge New Member
    Nov 19, 2014
    194
    28
    I think you will find that you can't use http on port 5000 from the public Internet. You must use SSL, which is typically going to be on port 5001 from outside.
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  4. asmith3006
    Mar 5, 2014
    94
    5
    That's exactly it, thank you.
