403 error
Discussion in '3CX Phone System - General' started by powerlinkpc, Jan 12, 2011.
  1. powerlinkpc
    Oct 20, 2010
    Hi Guys i am new to 3cx just configure my box .. i can get incoming call fine but when i try to dial an outboud call i get a busy tone.. ANy ideas what i am doing wrong??
    error
    @sip.broadvoice.com has failed; Cause: 403 Forbidden; from IP:147.135.20.221:5060
  2. spid3r1987
    Jul 12, 2011
    6
    did you ever sort this, i have the same problem but with different provider
  3. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Have you created outbound rule(s) for this provider (assuming you are registered successfully to the provider).
    Run the firewall checker as well.
    Regards
  4. willow
    willow Member
    Mar 1, 2011
    471
    it would be extermely helpful if you can post a log of an out going call. you will need outbound rules in order to make and route calls properly.
