403 Forbidden invite...
Discussion in '3CX Phone System - General' started by erdia, Jul 25, 2016.
  1. erdia
    Jul 11, 2016
    18
    Good morning, I have a problem with the calls. External calls I receive them well and where I placed and routed by all OK, but when making a call I get Forbidden 403. I put the log for you to help me. Not if it helps, but in SIP Domain Local I put my public IP. And the box not allow calls outside LAN is not checked. Thank you!
    25-jul-2016 11:32:22.123 Leg L:3.1[Extn] is terminated: Cause: BYE from PBX
    25-jul-2016 11:32:22.072 [CM503020]: Call(C:3): Normal call termination. Call originator: Extn:100. Reason: Forbidden
    25-jul-2016 11:32:22.072 L:3.1[Extn] failed to reach Line:10000>>93XXXXXXX, reason Forbidden
    25-jul-2016 11:32:22.072 Leg L:3.4[Line:10000>>93XXXXXXX] is terminated: Cause: 403 Forbidden/INVITE from 85.62.244.15:5060
    25-jul-2016 11:32:22.071 Call to T:Line:10000>>93XXXXXX@[Dev:sip:+3493XXXXXXX@sip.orange.es:5060] from L:3.1[Extn] failed, cause: Cause: 403 Forbidden/INVITE from 85.62.244.15:5060
    25-jul-2016 11:32:22.040 [CM503003]: Call(C:3): Call to <sip:93XXXXXXX@sip.orange.es:5060> has failed; Cause: 403 Forbidden/INVITE from 85.62.244.15:5060
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,064
    58
    Given the IP shown, which I assume to be the provider's, there is something in the INVITE that you are sending when calling out that they do not like. This is likely in the provider settings and the quickest solution is most likely to call them and ask them to trace the call whereupon they can advise as to what aspect is at fault.
    It is unlikely that the settings you mentioned in the post are the issue in this case, as those merely tell them where to send the responses.
  3. erdia
    Jul 11, 2016
    18
    But directly in a soft phone, call and leave me works perfectly. That problem is that the PBX
  4. lneblett
    Sep 7, 2010
    2,064
    58
    Sorry, but the fact that the soft-phone works is not an indication that the PBX is set the same. The fact is that the provider rejected the call as there was something that they did not like.
    You could possibly do a wireshark capture of the successful soft-phone call and then another of the failed 3CX call and compare the two and perhaps this may show the issue. You might also be able to look at the failed 3CX capture and look for a cause code in the response.
  5. erdia
    Jul 11, 2016
    18
    As you can get the log in the Zoiper? not like is to have the log zoiper
    [​IMG]
  6. lneblett
    Sep 7, 2010
    2,064
    58
    The logs are not detailed enough. Use Wireshark or call the provider.
  7. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  8. erdia
    Jul 11, 2016
    18
    [quote"Sopock"]that landline(?) provider might not like use of any PBX instead analog phones :!:
    http://www.3cx.es/?s=403[/quote]
    I don't know use Wireshark. And Sopock i don't understand your reply :S
  9. leejor
    10,585
    252
    When a device registers, it also sends a name to the server to identify the device. Years ago, there was a provider (whose name eludes me), that actually blocked registrations specifically from 3CX. I seem to recall that changing the User Agent, in the trunk settings, to something "acceptable", allowed the continued use of 3CX. In other words, you can spoof the name of the device you are using if necessary.
    That, however, may have nothing to do with the reason you are having this issue. As mentioned previously, the best way to resolve this quickly, is to talk to your provider, and have them tell you why you are getting the forbidden message.
    Does the trunk show as registered?
    If so, are you able to receive calls?
    If so, it may be the digits (format/length) you are sending to them.
  10. erdia
    Jul 11, 2016
    18
    Yes, the trunk is registered, and can receive calls correctly. The problem is when calling. Idk if such options will have to see FQDN
  11. leejor
    10,585
    252
    If the trunk is registered, and you are able to receive calls, then I would suspect that the forbidden message is because of the (incorrect?) digits you are sending, or an issue with your account.
