404 Not Found error on outbound call attempt
Discussion in '3CX Phone System - General' started by DataGuru, Oct 15, 2012.
  1. DataGuru
    Oct 14, 2012
    I've recently downloaded the Free Edition (for evaluation purposes) on a 32-bit Windows 7 64-bit OS and have deployed 1 SIP Trunk with 2 Channels. Inbound calls arrive with no problem but I receive a "404 Not Found" error when I attempt outbound calls. Have checked with the SIP Trunk provider and everything seems okay from their end when they trace an attempted outbound call.
    Any suggestions?
    10,842
    299
    It would probably help if you reviewed the 3CX log of the failed call. If nothing explains the failure, then post the log here. You can X out part of any public IP that is listed, for security.
  3. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    do you have proper outbound rule for dialed number?
