Banana Jack
- Joined
- Apr 2, 2008
- Messages
- 17
- Reaction score
- 0
Hi all
Everything is working with my new 3CX except I can't make outgoing ISDN calls through my Patton SN4634. Incoming and outgoing calls work through VOIP (sipgate) and incoming calls work through ISDN, but not outgoing through ISDN. Here is my server log:
22:40:29.682 Call::Terminate [CM503008]: Call(32): Call is terminated
22:40:29.650 Call::RouteFailed [CM503014]: Call(32): Attempt to reach [sip:[email protected];user=phone] failed. Reason: Not Found
22:40:29.650 CallLeg:nFailure [CM503003]: Call(32): Call to sip:[email protected]:5062 has failed; Cause: 404 Not Found; from IP:192.168.1.4:5062
22:40:29.588 CallLeg:nFailure [CM503003]: Call(32): Call to sip:[email protected]:5060 has failed; Cause: 404 Not Found; from IP:192.168.1.4:5060
22:40:29.510 CallCtrl:nSelectRouteReq [CM503004]: Call(32): Calling: PSTNline:10001@[Dev:sip:[email protected]:5060, Dev:sip:[email protected]:5062]
22:40:29.479 CallCtrl:nIncomingCall [CM503001]: Call(32): Incoming call from Ext.10 to [sip:[email protected];user=phone]
192.168.1.4 is my Patton SN4634
192.168.1.10 is my 3CX server
I loaded the config file from 3CX into the Patton but I think I must need to make some more configuration changes - can anyone please help me? I am only using 1 of the unit's 3 ISDN2e ports, if it makes a difference (BRI 0/0).
Thanks for any help! I think this will be the last hurdle to deploying the whole system.
Glenn
Glenn
