404 Not found in Server Log
Discussion in '3CX Phone System - General' started by crsc, Dec 27, 2007.
  1. crsc
    Dec 1, 2007
    28
    What is the meaning of 404 Not found on the error below?
    12:31:26.464 CallLeg::eek:nFailure [CM503003]: Call(20): Call to sip:17187797030@192.168.16.119 has failed; Cause: 404 Not Found; from IP:192.168.16.119
    A second question, do 3CX has a list of error codes and descriptions to help analyse the log file?
    Thanks.
  2. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    A list of errors would be very helpfull for us novices
  3. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    not found means that the number you dialed could not be found, this can happen becouse, you dialed the wrong number, your outboud rules are not set correctly.... or something else i cant thing of now...
    Cheers
