404 not found on deploy
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Sep 21, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I'm now deploying on a 64bit windows server 2008 box
    Why is the following config giving me a 404? I have confirmed the files are there and the IIS server is set up properly.
    <?xml version="1.0" encoding="utf-8"?>
    <Graphical_Application_Designer_Project>
    <Version>1.0</Version>
    <Files>
    <File path="GetAgentPhone.comp" type="component" />
    <File path="Main.flow" type="callflow" pbx_callflow_name="CellsAgent" activation_extension="855" activation_extension_debug="856" />
    <File path="MenuOptions.comp" type="component" />
    </Files>
    <Variables>
    <ArrayOfVariable xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" />
    </Variables>
    <PbxServer>10.123.86.3</PbxServer>
    <PbxConfigurationPort>5485</PbxConfigurationPort>
    <PbxDeploymentUri>http://10.123.86.3:5484/VAD_Deploy.aspx</PbxDeploymentUri>
    <PbxDownloadDebugFilesUri>http://10.123.86.3:5484/VAD_DownloadDebugInfoFile.aspx</PbxDownloadDebugFilesUri>
    <PbxGetDebugFileNamesUri>http://10.123.86.3:5484/VAD_GetDebugInfoFileNames.aspx</PbxGetDebugFileNamesUri>
    <NextCallflowActivationExtension>854</NextCallflowActivationExtension>
    <DebugBuildSuccessful>True</DebugBuildSuccessful>
    <ReleaseBuildSuccessful>True</ReleaseBuildSuccessful>
    <DebugBuildNumber>80</DebugBuildNumber>
    <ReleaseBuildNumber>80</ReleaseBuildNumber>
    <ChangedSinceLastDebugBuild>True</ChangedSinceLastDebugBuild>
    <LastDeployedConfiguration>Debug Build</LastDeployedConfiguration>
    </Graphical_Application_Designer_Project>
  2. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    I discovered the problem but not the solution.
    In the file VAD_Deploy.aspx.cs you guys are reading the session variable Request.QueryString["projectname"]
    When I go to the url for vad_deploy.aspx manually in a browser, the error comes up for OBJECT REFERENCE NOT SET TO AN INSTANCE OF AN OBJECT.
    I confirmed that this is the problem.
    What would make the VAD not pass the projectname in the query string?
  3. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    I'm a bit confused. A 404 error should happen if the page can not be located. An error like not sending the projectname in the querystring should report a 500 error (internal server error).
    Can you try browsing manually to http://10.123.86.3:5484/VAD_Deploy.aspx?projectname=PROJECTNAME and see what happens?
  4. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Either that or there is more than one problem here. Because it was a 404 error I checked if all the files existed, and they did. When I manually ran the .aspx page I got the object error, but I just realized it probably errored when I checked it in the browser because I wasn't specifying anything in the querystring.
    So just forget about that part. The main problem is the 404 error is happening but the file exists.
    I checked the url and received:
    ERROR: projectname is invalid
  5. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Ok, I got this to work in the browser
    http://10.123.86.3:5484/VAD_Deploy.aspx?projectname=CellsAgent_Debug
    I forgot the "_Debug" before.
  6. VAD_Support
    Aug 6, 2009
    690
    So, could you finally deploy the project? Or are you still getting the 404 error from the VAD?
  7. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Still getting the 404 from the VAD.
  8. VAD_Support
    Aug 6, 2009
    690
    This is very strange...
    Just to be absolutely sure about what's going on, can you trace with WireShark a manual request to http://10.123.86.3:5484/VAD_Deploy.aspx?projectname=CellsAgent_80_Debug? And another request using the VAD? I would like to see what is the difference between both requests...
  9. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Do you want a raw data dump?
  10. VAD_Support
    Aug 6, 2009
    690
    Yes, the dump from wireshark, so we can open it here and see the difference.
