404 Not Found with Voiceflex
Discussion in '3CX Phone System - General' started by MartinC, Nov 13, 2014.
  1. MartinC
    Nov 13, 2014
    5
    Has anyone got any ideas on this one? I have just set up the trial version of 3CX and registered a SIP trunk with Voiceflex. I can receive calls with no problem, but cannot make outgoing calls.
    In the logs I get a '404 Not found' error, so I contacted Voiceflex support to ask if they had any guides to configuring their SIP trunks on 3CX, or why I was getting this error. The response I got was:
    Does anyone know how to get 3CX to send the invite again after the 404?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,587
    309
    I thought 3cx did this by design up to 3 times... Maybe I am thinking of something else.
    What country are you in?
  3. MartinC
    Nov 13, 2014
    5
    I'm in the UK. Here's the log of what's happening:
    13-Nov-2014 09:31:43.309 NAT/ALG check:L:7.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    13-Nov-2014 09:31:43.310 [CM503001]: Call(C:7): Incoming call from Extn:1874 to <sip:02037351878@10.82.95.251:5060>
    13-Nov-2014 09:31:43.311 Call(C:7): Call from Extn:1874 to 02037351878 matches outbound rule 'Route Via VoiceFlex'
    13-Nov-2014 09:31:43.311 Line limit check: Current # of calls for line Lc:10000(@VoiceFlex[<sip:84422763@sip20.voiceflex.com:5060>]) is 0; limit is 1
    13-Nov-2014 09:31:43.311 [CM503004]: Call(C:7): Route 1: from L:7.1[Extn] to T:Line:10000>>2037351878@[Dev:sip:84422763@sip20.voiceflex.com:5060]
    13-Nov-2014 09:31:43.311 [CM503027]: Call(C:7): From: Extn:1874 ("Martin Test" <sip:1874@10.82.95.251:5060>) to T:Line:10000>>2037351878@[Dev:sip:84422763@sip20.voiceflex.com:5060]
    13-Nov-2014 09:31:43.381 [CM503025]: Call(C:7): Calling T:Line:10000>>2037351878@[Dev:sip:84422763@sip20.voiceflex.com:5060] for L:7.1[Extn]
    13-Nov-2014 09:31:43.623 [CM503003]: Call(C:7): Call to <sip:2037351878@sip20.voiceflex.com:5060> has failed; Cause: 404 Not Found/INVITE from 93.95.124.20:5060
    13-Nov-2014 09:31:43.623 Call to T:Line:10000>>2037351878@[Dev:sip:84422763@sip20.voiceflex.com:5060] from L:7.1[Extn] failed, cause: Cause: 404 Not Found/INVITE from 93.95.124.20:5060
    13-Nov-2014 09:31:43.623 Leg L:7.2[Line:10000>>2037351878] is terminated: Cause: 404 Not Found/INVITE from 93.95.124.20:5060
    13-Nov-2014 09:31:43.623 L:7.1[Extn] failed to reach Line:10000>>2037351878, reason Not Found
    13-Nov-2014 09:31:43.623 [CM503020]: Call(C:7): Normal call termination. Call originator: Extn:1874. Reason: Not found
    13-Nov-2014 09:31:43.674 Leg L:7.1[Extn] is terminated: Cause: BYE from PBX
  4. craigreilly
    Feb 1, 2012
    3,587
    309
    I do not see that they are an approved provider in 3cx. Not saying it will not work - but there are reasons that certain providers are listed.
    A wireshark of the call will give you much more detail than the 3cx logs.
    Perhaps install x-lite and use the credentials there, just to ensure you have the correct information as well.
