4128 Memory Leak
Discussion in '3CX Phone System - General' started by rnoguera, Feb 23, 2008.
  1. rnoguera
    Oct 25, 2007
    89
    After some hours running, 3CX, uses 800Mb memory (instead of 9Mb) and all available processor power. Restarting the service fixes the problem. Somebody else is having that problem?
    O.S. is Windows 2003 Server.
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello
    yes this happen to me also, running w 2003 server
    cheers
  3. Remy
    Feb 24, 2008
    Have version 4128 running on W2003 SP2 fully patched, after 2 days only 11Meg of ram and approx 4% cpu.
    Hardware is intel mini atx fanless celeron 1200 with 512Meg. 2 voiplines,1 pstn and 5 users
    Remy
  4. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    All seems fine with my 3CX running on XP SP2 10,128kb RAM used by 3cxPhoneSystem.exe
  5. hagesol
    Mar 26, 2007
    22
    Hi,,,
    I have the same problem with vista home premium 32 bit. I have start an stopp all the 3cx applications - When I turn off 3cx Phone system media server, the cpu is going down to normal... And when I start the media server the cpu is going up to 100 %.
    My computer;
    AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ 2.60 GHZ with 3 gb ram
    Any fix for this problem?
    Lars
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I had a client experience this today. They were having audio problems - one way could hear the other couldn't. Restarted the services and all is well again.
    I'm going to schedule a services restart every day at 2am to avoid this until a fix or something comes up.
  7. rnoguera
    Oct 25, 2007
    89
    I did a backup + deinstall + install +restore backup and the problem apparently dissapeared.
  8. Resolve
    Sep 19, 2007
    94
    Add me to the list....
    We have a client that is experiencing random one way audio. usually after a transfer.
    We notice that the server log has *very* frequent stun request to stun server errors. Reboot and all is well
    Tim
