4316: Bug Report: Caller ID
Discussion in 'Windows' started by darrellchapman, Mar 24, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    Build 4316 is still only showing the extension number for internal client calls rather than the defined CallerID in 3CX.
