4510 Memory Usage
Discussion in '3CX Phone System - General' started by HatchITMan, May 12, 2008.
  1. HatchITMan
    Dec 18, 2007
    18
    I am running Version5.1.4510.0 on Windows 2003 SBS. There appears to be a memory leak in 'PhoneSystem.exe'. This process starts using about 8k, then 3 days later is at 476k and growing fast.
    The previous build which was only current for a short while also exhibited the same problem.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,926
    241
    Re: 4510 - processes
    Phonesystem.exe would take much more then just 8k or indeed 496 k. In fact there is almost no process on windows that takes 8k or indeed 496k. Please be sure about you what you are posting before you conclude memory leak
  3. Nick Galea
    Jun 6, 2006
    1,926
    241
    Re: 4510 Memory Leak
    No problem. Do you have a copy of 3CX Call Assistant running by any chance? This was an old 3.1 component and is known not be compatible with v5.1
  4. HatchITMan
    Dec 18, 2007
    18
    No copies of Call Assistant in use at all.
  5. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    Hi - Can you send us a screenshot of Task Manager and try and grab the whole lot of the 3CX services.
    When 3CX starts, yes it starts in the range of 8 - 9 mb. When it is idle it is normal for 3CX to occupy 9500 k to 12000k. So at least we know that your 3CX machine is starting right.
    Under extreme bulk testing we have seen it rise to 50 / 90 Megs but it is acceptable because of the amount of calls it is handling. When we turn off the tests it will start going down again. This will automatically rule out a memory leak.
    Just to be on the safe side - can you try and installing 3CX phonesystem (same version) on another computer? See what happens?
    Can you also download 3CX and perform a fresh installation? Maybe the installation got corrupted in some way and started to pose these kind of problems.
    Please also upload a backup file of your configuration - We will upload it on our test bed to be able to exclude some sort of infinite loops in the config.
    Also - can you describe the CPU usage of the process when it is at that amount? And how many simultaneous calls do you have going at the time of the rapid increase of memory?
    thanks
  6. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Do you use 3CX PBX as "test environment"?
  7. HatchITMan
    Dec 18, 2007
    18
    We are not using the phone system as a test system. We are only a small organisation, with 1 PSTN line (SPA3102a gateway) and one VOIP provider (Sipgate). We have 3 extensions.
    I have not got the resources, at the moment, to install the system on another computer.
    I started yesterday recording memory usage for my peace of mind. The first result was:-
    15:01 12th May 2008
    3CXFaxServer.exe SYSTEM 00 30,144K
    3CXIVRServer.exe SYSTEM 00 12,272K
    3CXMediaServer.exe SYSTEM 00 19,244K
    3CXPhoneSystem.exe SYSTEM 00 9,392K
    3CXTunnel.exe SYSTEM 00 3,592K
    3CXVBMServer.exe SYSTEM 00 6,060K
    This was recorded immediately after restarting the PhoneSystem task.
  8. Nick Galea
    Jun 6, 2006
    1,926
    241
    This should be about right (the memory usage). Lets check again in a day or so.
  9. HatchITMan
    Dec 18, 2007
    18
    Memory use at 09:15 19th May 2008
    3CXFaxServer.exe SYSTEM 00 30,160K
    3CXIVRServer.exe SYSTEM 00 12,888K
    3CXMediaServer.exe SYSTEM 00 19,880K
    3CXPhoneSystem.exe SYSTEM 00 19,484K
    3CXVBMServer.exe SYSTEM 00 6,072K
    All readings were taken with the system idle. PhoneSystem.exe is growing, is this expected?
  10. Nick Galea
    Jun 6, 2006
    1,926
    241
    Its normal to vary a little - we consider it a normal range for it to be in.
  11. nb
    nb Support Team
    Jun 7, 2007
    2,127
    152
    Ok
    Let's give it more time. Remember that this increase is reflecting components needed by the 3CX Phonesystem that were used during this period and weren't as yet present at the time you restarted the services. As you use the pbx, more components kick in and therefore more memory is needed. But 19Megs is ok.
    Keep us informed please, taking snapshots as you go along.
  12. HatchITMan
    Dec 18, 2007
    18
    I have been monitoring the memory usage since 22nd May. Until 6th June the memory used by the PhoneSystem task had only risen slightly, but over the weekend there has been a huge increase. The memory use is as follows:-
    6th June 9th June
    Fax 30,164k 30,164k
    IVR 13,036k 13,366k
    Media 20,400k 20,412k
    Phone 30,078k 98,588k
    Tunnel 3,612k 3,608k
    VBM 6,140k 6,140k
    I have snapshots recorded every working day sonce 22nd May. I will keep wathcing.
  13. HatchITMan
    Dec 18, 2007
    18
    The last test was performed at 09:00 this morning. It is now 15:40, and the memory usage has increased to 250,512k for the PhoneSystem task. It is increasing at 4k per second, so I will have to shut down the service and restart it shortly.
